ok, I just want to clarify that stacking is legal.
"Rule 2. A Scoring Object is not fully below the top of the PVC pipes of a Circular Goal and partially within
the outer ring of the Circular Goal. (See figure 5) "
First: It is implied that the projection of the outer ring from the floor to infinity above the goal determines a scored object. Correct?
Second: A robot holding a stack of game objects above a goal and partially within this projection would score all the objects except the ones touching the robot. I.e. a “pancake” stack held by the bottom piece would score all but the bottom piece. Correct?
Thanks
