Answered: Arcade channel mixing question
I’m using the Vex transmitter in arcade mode for a project and am running into a problem with the channel mixing. Full forward on the stick does not result in full power to the motors; a motor will only run at full speed when going full forward and turning at the same time (stick held full forward and full right, for example).
Is there a way to change this in the transmitter? I would like to have full power to the motors when the stick is held full forward without resorting to tank drive mode.
Thanks,
Steven
Yes this can be done but not in the Transmitter - mixing will be done in the VEX Microcontroller. Please refer to the Alternate Arcade-Style Controls in the Inventor’s Guide Appendix “Control”.
