Answered: continous motor without order
i programmed my bot using easy c v2, i used the 2 arcade feature, the left motor in port 1 and the right motor in port 2 and the forward channel is 2 and the rotate channel is 1 i compile de proyect then download it and when i turn the controller on the right wheel that is attached t the roght motor moves i have tried with other motor and the same thing happens, i used the same port with another motor and it worked fine
i forgot that the write that the trim is in 0
Glad you solved your problem.
