Answered: cortex and easyC v4
Hello i am very new at vex and just got a vortex controller. I was wondering how u download a program wirelessly and how do u “run” the program? I have already tethered the joystick and the cortex. I have also updated the firmware. Thanks
To program wirelessly you need a 276-2186 Programming Hardware Kit. Connect it between the PC and the Joystick’s Program Port. Then build and download the program. The CORTEX will reset after download and automatically run your program.
ok i have done that and the Easy C4 will not download to the joystick
Can you download User or Default Code using a USB A-A Cable?
yes i can to the robot
I recommend making sure, you have the mastercode up to date on both the Joystick and the Cortex. Then pair the devices together, you should then have no issues programming your cortex over tether or wifi.
I then recommend you go through the 14 tutorials to help familiarize yourself with easyC.
