Answered: Defining 18 x 18 x 18 parameters for small temporary expansion
Hey Karthik. i was wondering what would be the ruling if tank tread flaps were outside the confines of the box while outside the climbing zone. Would this be egregious? would a team be penalized for this or would this be excused? thanks
Let’s take a look at the specific rule in question.
Although this may not be egregious, earning repeated warnings for doing so could result in a DQ. Also, if the only way your tank treads work is by being outside of the 18"x18"x18", any points scored for balls that were accumulated by these treads would immediately be considered when determining if the foul was match affecting.
Simply put, you need to find a way to keep these tank treads within the volume limitations to avoid being penalized.
Thank You!
You’re welcome!
