Answered: Did these balls get scored?
We have some questions about when a ball is regarded as scored and/or out of play
In the attached photos we ruled that none of the balls in the basket were scored as they were touching a robot of the alliance that the scoring zone belongs to. This is fairly clear in the ‘Scored’ rule.
What would be the case if one of the balls in the basket was not touching the mechanism of the robot, was within the scoring zone but was held in place by other balls that were touching the mechanism? {The top ball in photo P1040561.jpg shows a ball that could have been in this category if it had been in the scoring zone}
When does a ball get scored? The simple approach would be to say that as a ball travels from one scoring zone to another it goes from being scored, to out of play (over the center wall) and then back to being scored. In this case all the balls are effectively out of play as they have left one scoring area but have not yet met the conditions required to consider them scored on the other side of the wall. (still touching the robot)
Is this the intent of the rules or do the balls in the hopper count against the robot storing them as it failed to get rid of its load?
The mechanism of the robot in the photos is deliberately crossing the field border. Rule <S2> says not to penalize robots for having mechanisms that inadvertently cross the field border but this design relies on substantial crossing as part of its action to dump the balls.
We read the intent of the rules is to allow this as long as the foam surface is not touched and you do not want to limit robot design. Is this correct? If it is correct then is there a case where crossing the wall would be considered too much?
Rule <G4> says that balls that leave the field are considered out of play. Are we correct in assuming that if some or all of the balls in the same hopper were to go out over the back wall or a side wall then those balls would be out of play or does contact with the robot keep them in play?
If they are out of play then the hopper cannot be brought back into the field (unless it is emptied as you cannot return balls to the field. Is this correct?
[quote]
<G4> Balls that leave the playing field are considered out of play. These objects will NOT be returned to the field.
[/quote]
Okay… based on the definitions of “Scored”, “Ball”, “Center Wall”, “Locked Up”, “Goal”, “Robot”, “Alliance”, “Scoring Zone” also based on the Game Rules listed in the “Scoring” section, and also based on rules <G4>, and <SG4>…
Here are ALL the possible ball configurations, and the way they should be scored:
[LIST]
*]Touching a BLUE Robot in the BLUE Scoring Zone - NO POINTS
*]Touching a BLUE Robot in NO Scoring Zone - NO POINTS
*]Touching a BLUE Robot in the RED Scoring Zone - RED POINTS
[/LIST]
[LIST]
*]Touching NO Robot in the BLUE Scoring Zone - BLUE Points
*]Touching NO Robot in NO Scoring Zone - NO POINTS
*]Touching NO Robot in the RED Scoring Zone - RED POINTS
[/LIST]
[LIST]
*]Touching a RED Robot in the RED Scoring Zone - NO POINTS
*] Touching a RED Robot in NO Scoring Zone - NO POINTS
*] Touching a RED Robot in the BLUE Scoring Zone - BLUE POINTS
[/LIST]
Balls “out of play” refer to balls outside the field perimeter where robots cannot get them. These balls would be in “NO Scoring Zone”.
There is no mention in the rules about balls in a basket. The rules only mention touching. The ball is either touching the robot, or it isn’t. Based on this, refer to the above list of ball scoring configurations to determine how the ball should be scored.
First off, you are misusing the term “out of play”. Balls are only considered “out of play” when they have left the playingfield, and robots cannot get them. These balls will not be returned to the field. See <G4>.
Balls are scored at the end of the match per <G7>.
At this time, balls will either be:
[LIST]
*]Scored for Red
*]Scored for Blue
*]Not Scored (out of play balls are considered not scored).
[/LIST]
It does not matter what state transitions the balls make during the match, it only matters what state they have when the match is scored. See the list of possible ball configurations above, and score accordingly.
Yes, a ball in a hopper can be scored against the robot holding it depending on where that ball “ends the match”.
This mechanism seems acceptable. The only rule which talks about crossing the wall is <SG4> which states:
If you don’t touch the tiles on your side of the field, you can extend over the wall as much as you want. If you touch the tiles, the referee would make a determination about whether you should be disabled. The referee would decide whether the contact was an accident, or whether your strategy was deliberate enough that you should be penalized.
I don’t see any risk of the robot in the images you posted touching the foam tiles.
“Out of Play” is not defined in the manual, but we can use common sense to infer that if a ball is in a robot, then it is still “in play”. The robot is still playing with it… :wink:
This rule means that if a ball leaves the field and rolls away from a robot, the field reset people won’t pick it up and put it back… nothing more.
See above. Play on!
I moved this thread into the Official VRC Clean Sweep Q&A. It seemed like you wanted an official ruling, not a community discussion.
-John
Wow!
Thank you for a very detailed response.
As it usually does with VEX we are glad that the KISS (Keep It Simple Stupid!) principal applies.
