there is this part
http://www.vexrobotics.com/products/accessories/structure/275-1254.html
i was just making sure that this part
[http://www.mcmaster.com/#86225k53/=gjehiw
would count
under R7
Any parts which are identical to legal VEX parts. For the purposes of this rule, products which
are identical in all ways except for color are permissible. Note: It is up to inspectors to
determine whether a component is “identical” to an official VEX component](http://www.mcmaster.com/#86225k53/=gjehiw)
would count
under R7
Without seeing the foam offered by McMaster, it’s impossible to tell if it is identical in all ways. The decision will be made by the inspectors at the event. If the foam is critical to your design, I advise you to play it safe and go with the VEX foam.
it isnt money wise it is size wise
vex only has it in strips i wanted a sheet
I didn’t realize it was sold in sheets. This would definitely be illegal. If the two items are different sizes, they clearly are not identical.
