I have a series of questions regarding the definition of Field Element and SG8.
(1)
I would like to clarify if the hanging bar is considered as one of the supporting structures.
I presume it is not listed as a field element so that robots can latch on it and hang itself up.
But I thought it will be better to get a confirmation - as it will affect the design of the hanging mechanism.
(2)
If hanging bar is considered as a field element, then it is obvious we are not allow to grasp or gapple or attach to it.
(a)
But if it is not a field element, the next question will be -
Are we then allow to anchor our robot against the hanging bar (assuming no other field elements are touched by the robot) in an attempt to block the opponents from scoring?
(b)
And will it makes a difference to the ruling if it is touching the opponent’s hanging bar (and assuming no other field elements are touched by the robot) instead?
I put these 2 questions in a same post because they are related to my queries.
Thank you so much for your time to read through this series of questions.
