I just have to bring this up, because it has been bothering me for a while…
The web page Vex Robotics Design System shows the following under Inputs and Outputs:
Battery Input 7.2 volts nominal, 6 to 9 volts min/max input range
Interrupt Inputs 6
Digital I/O 16 max with no Analog, Each can be Input or Output (shared with Analog)
Input Impendence
Analog/Digital - The input consists of a 470K pull-up to +5V and a series resistance of 1K to the uP.
Interrupts - The input consists of a series resistance of 1K to the uP. More info - Input Schematic.
Analog Inputs 16 max with no Digital, 10-bit resolution (shared with Digital)
Digital/Analog as Inputs
3 dB bandwidth of 150 kHz, weak pull-up of 470k-ohms to 5.0 volts,
need 0.0 to 0.6 volts for a low and 4.0 to 5.0 volts for a high
Interrupts as Inputs
3 dB bandwidth of 150 kHz, weak pull-up of 47k-ohms to 5.0 volts,
Digital/Analog Interrupts as Outputs
As outputs these ports can drive an open circuit to 0.6v or lower for a low and 4.0 volts or higher for a high.
They can drive a 1 mA load to 1.6v or lower for a low and 3.0 volts or higher for a high.
PWM Outputs
They can drive a 1 mA load to 1.0v or lower for a low and 3.6 volts or higher for a high.
The Digital/Analog Interrupts as Outputs and PWM Outputs don’t make much sense to me as far as telling me what the Maximum Output they can drive. The really Interrupts, or is this just an editing error???Current DrawPWM OutputsinferDigital/Analog Interrupts as OutputsdrivereallyDigital/Analog Interrupts as Outputs
