Answered: LED Help
Is there any way to hook-up a led to the microcontroler? If so, how?
Answer: https://vexforum.com/showthread.php?p=552#post552
Thankes Ricky!:smiley:
I still can’t get a led to work. I’ve tried averything from PMW to Motor ports and nothing works. :confused: I need directions!
You must know basic electronics to do this task which will not be covered in this forum. How much current does your LED require? How does that compare to the Vex Controllers Digital Outputs? Are you trying to source or sink current to the Digital Output to turn on the LED?
