I tried to make the line follower work but it’s just seems to waste my time, as I kept adjusting the height and I didn’t see obvious changes of the returns.
Is there any tip for using a line follower? thanks a lot.
**Line follower issues are well covered and resolutions can be found by doing a forums search.
Try these links for example (found by doing a forums search):
https://vexforum.com/t/omaha-vex-regional/15363/1**
http://www.education.rec.ri.cmu.edu/roboticscurriculum/vex_online/programming/easy_c/line/LineFollower2sensors.htm
