Answered: Match Loading Clarification
To clarify configuration changes from previous answer…
In the process of match loading, as coach/driver pushes in objects into a robot intake like this one:
http://farm7.static.flickr.com/6171/6148419783_d0f1248ef9.jpg ,
Can intake treads turn from the force of objects being pushed in or is this considered “changing the configuration of the Robot”?
Thanks in advance.
The type of movement you described would not be considered a change of configuration, thus would not fall under <SG5> of the [VEX Gateway Manual, which is quoted below for clarity.
](“https://vexforum.com/wiki/index.php/Gateway”)
