Answered: Motors spinning
Our motors begin spinning as soon as we turn on our transmitters. I have tried re programming them but they continue to spin.
**Are you using the a 3 wire or 2 wire motor, and if you are using a 2 wire motor are you using the Motor Controller 29 along with it?
http://www.vexrobotics.com/products/accessories/motion/276-2193.html
Does this happen on all Motor Ports and which Microcontroller are you using, the PIC or CORTEX? By re-programing are your refering to Master Code or User/Default Code or both. It you are not using Default Code, please try using that.**
I am using a 2 wire motor but I am using the motor controller 29. Yes it happens on all motor ports. I am using a pic controller. I have downloaded the default code, however it still starts spinning as soon as I turn the controller on.
If this happens on all Motor Ports, you need to contact our Tech Support (903)-453-0802 and get a RMA Number for the return of the system to us for repair.
