I looked in the rule manual and I wasn’t able to find where it talks about the orientation of the objects at the start of a skills run. In the field appendix, page 11, it talks about the orientation of the objects at the start of a regular match, but not during skills. In the appendix b, robot skills challenge, it shows a picture of the field set up for a skills run, but the orientation of the objects is different than a regular match. What I really want to know is if the cube that starts on the starting tile opposite of where the robot is, can it be turned in any orientation?
The Cube that starts a Skills Match on the Alliance Starting Tile should be approximately oriented such that it’s sides are parallel to the field perimeter walls.
