At what point does a tube of your color interacting with an opponent robot count for no points?
If the opponent robot is touching the tube in any manner, it is worth nothing.
If the opponent robot is holding the tube (i.e. no contact between the tube and the scoring goal/wall or another tube on it), it is worth nothing.
When the opponent removes the tube from the vertical cylinder defined by the goal post and a given distance (either outer radius of tubes or or radius of goal post) from its center, it is worth nothing.
This answer has been updated in the following post to reflect the new manual edition from 11/17/2010. This answer only remains here as an archive. Please see the post from 11/18/2010 for the correct answer.
Let’s take a look at the definition of scored:
There is no mention of an opposing robot in this definition, thus a tube will be considered scored as long as it meets one of the two listed criteria, regardless of any contact with an opposing robot. So, in scenarios 1 & 2 the the tube is still legally scored. In scenario 3, the tube would no longer be scored once it no longer meets one of the two criteria from the definition.
By the definition stated:
Let’s say the goalpost held the tubes:
1[red]
2[red]
3[red]
4[blue]
If a blue robot was removing the tubes from the goalpost and in contact with tube 4, then if 1, 2, and 3 are above the goalpost, all 4 tubes are worth nothing because they are not in contact with a tube that is “scored” nor fully below the top of the goal post, correct?
If a blue robot was in contact with the tube 4 lifting the entire stack, but tube 3 is still fully under the goal post (i.e. buzzer rings while descoring is happening), then tubes 1-3 are scored, 4 is not, and the goal is owned by red with 3 tubes (1 and 2 are on top of 3, which is legally scored)?
Another situation:
1[red]
2[blue]
3[blue]
If a blue robot lifts from tube 3, and at the end of the game tubes 2 and 3 are fully underneath the goal post, then tube 2 is legally scored by definition one, and tube 1 is legally scored by definition 2, and the goal is not owned by either alliance (1-1)?
Correct. The blue tube [4] is not scored because it is in contact with a robot of the same color. The red tubes [1-3] are not scored because they are not fully below the top of the goal post or in contact with another scored tube.
Correct. The blue tube [4] is not scored because it is in contact with a robot of the same color. Red tube [3] is scored because it is fully below the top of the goalpost. Red tubes [1-2] are scored because they are in contact with other scored tubes.
Correct. Blue tube [3] is not scored because it is in contact with a robot of the same color. Blue tube [2] is scored because it is fully below the top of the goalpost. Red tubes [1] is scored because it is in contact with other scored tubes.
Let’s take a look at the new definition of scored:
There is no mention of an opposing robot in this definition, thus a tube will be considered scored as long as it meets the listed criteria, regardless of any contact with an opposing robot. So, in scenarios 1 & 2 the the tube is still legally scored. In scenario 3, the tube would no longer be scored once it no longer meets the definition.
The new definition of scored does mention contact with other scored tubes or being below the top of the goalpost. Tubes must encircle the goalpost or projection of the goalpost to be considered scored.
Again, this situation no longer is an issue with the new definition of scored. Tubes are scored if they encircle the goalpost or it’s infinite projection and are not touching a robot of the same colour.
What does encircle mean? If the axis defined by the post intersects the distance between the inner and outer radius (i.e. a robot is holding it in place above the goal post when power is cut), is it counted? In other words, is “encircle” restricted to the inner circle of the radius, or the outer circle?
Also, does this mean that a robot can be contacting its own colored tube and still have the tube be in scoring position? No longer does the robot have to have released the tube, correct? In other words, points can be scored with tubes without any tube actually touching the wall or the goal posts?
