Answered: Pin Or Trap Question
Using the term match affecting, what would you consider to be a match affecting violation vs a non-match affecting violation about pinning? Is it based on the assumption by the history of the pinned robot? How would it be decided if a robot hasn’t competed before and it was the first match? If it’s based on the assumption of the history of the pinned robot, could it be possible that a robot with a good record could’ve actually tanked that match? If that’s true, can’t I assume that the robot pinned would’ve tanked anyways, and I could intentionally pin that robot for longer than 5 seconds?
One which results in a change of the winner and the loser of the match.
Please see this Q&A post, specifically the section quoted here for reference:
In general, referees should not issue a Disqualification unless they’re fairly certain that the action changed the outcome of the Match. They should also take previous formal warnings into account. That is, a team with no warnings should receive some “benefit of the doubt”, while one who has been warned in every match gets closer to a Disqualification at the referee’s discretion, Match Affecting or not.
Pins lasting longer than 5 seconds could result in a greater likelihood of being interpreted as Match Affecting. You also may stack up multiple warnings for non-Match-Affecting violations and result in a Disqualification at the head referee’s discretion.
