Answered: Pneumatic configuration rules
I have not been able to find rules for the configuration of a pneumatic system for the Clean Sweep competittion. Is there an extra document somewhere?
E.G. How many pistons can be used? How many ballast tanks can be used? What is the max pressure that you can charge the system to?
Also can you get replacement valve driver cables?
There are no rules limiting the number of pistons or ballast tanks that can be used.
The VEX pneumatic system is rated at 100 psi. Charging it to a higher pressure would be considered “unsafe” and constitute a violation of <S1>.
The Pneumatic Solenoid Driver’s are now available for purchase:
https://vexforum.com/t/vex-pneumatic-solenoid-driver-cable/16032/1
