I was wondering if using the pneumatics kit for cooling off a motor would be legal. Instead of the tube attaching to the piston, it would blow air onto the motor.
There are no specific rules prohibiting this action, thus it is legal.
So, since only the pneumatics have a limitation to 100psi, and the tank has a limit of around 200psi, can the tank be charged to 200psi? I understand that if anything happens then (as in the tank blows up) that it is our fault.
Yes, this is a correct assessment.
Ok thanks Karthik. Do you happen to know what the maximum pressure is for the double acting solenoid valves?
I do not, but you may have better luck getting an answer if you pose this question to the entire community in the general forum.
OK. Thanks
You’re welcome.
