I have been using Vex in my pre-engineering class for the past three years. Lately I have been experiencing a similar problem on a few of our robot controllers. After a download is complete the program gets stuck in the first function block without continuing on in the code. For Example- As a test we set up an open loop program with a single motor module. After the program is built and downloaded the robot wheel spins forever. We tried downloading the default code but that had no effect.
Any ideas?
Have you tried restoring the master code as well? Are you able to get the default code downloaded to it?
I did reload the master code. However, I just updated EasyC. Can I assume the master code will be updated?
The Master Code will not automatically update into the Microcontroller – you must do this task.
