At a skills event I refereed at, a team asked for their programming skills run to end early. However, there was a slight delay between when they asked for the run to end and when the person controlling the field actually ended it, and as a result their robot continued moving and ended their run in contact with two cubes which were scored in a floor goal, cancelling those points.
The team argued that because the person controlling the field had not promptly ended their run, as a result costing them two points (which, had they scored them, would have put them in first place at the event), they should be allowed another attempt. I ruled that the score should stand as is and without any additional attempts for three reasons:
Allowing teams to end early seems meant more as a courtesy to all involved to prevent a robot sitting there doing nothing for 45 seconds rather than something to be utilized to precisely end a run exactly when the team wants
The idea behind programming skills is to have minimal human interaction, calling an end to a run in order to indirectly control your robot seems to go against that spirit
allowing replays because the person controlling the field was not fast enough in ending a run would lead to far too many replays, which should only be issued in extreme circumstances
was my call correct?
