Hi Karthik,
Just a clarification on this Q&A.
I believe the original question was regarding moving an object from Clause 1, to Clause 2 but not descoring it.
Is this what you were referring to? Ie. would it be illegal to move an object from Clause 1 to Clause 2, and then drop it into the goal again, such that at no point during the action the object was ever in a not-scored position?
If so, could you elaborate on when the “even if it no longer meets the clause 1 requirements.” part of <SG9> would come into play?
Note: in no way would this create a loophole for descoring Clause 1 objects, they have still been scored under Clause 1 at one point in time, and so cannot be descored. It just allows, for example, descoring of legally descorable objects by pushing a Clause 1 object up, such that the top object falls off, and then releasing the Clause 1 objects such that they fall back into the goal.
Thanks
