3921
June 2, 2015, 12:55pm
1
<SG6> Any Scoring Objects introduced during the Match as Driver Control Loads must be either
gently placed on a Robot of your own color touching the Loading Zone or gently entered into the
Loading Zone of your own color, by a Student Drive Team Member, without breaking the plane of the
field, during the Driver Controlled Period. The intent of this rule is to allow teams to introduce objects
into play, but not to impart energy on the Scoring Object which will cause it to end up in a position
outside the Loading Zone.
I did not see any rule limiting how many driver loads you may place in your loading zone at once. I am wondering if we are allowed to place as many driver loads into the loading zone that will fit, given that we only pick up four at a time with our robot.
You did not see a rule limiting the number of Driver Control Loads you may load into your Loading Zone since the limit does not exist.
3921
June 3, 2015, 11:29am
3
Well that’s good information to know Thanks Karthik!
