R15a states you can not use a wire for anything other than its intended use. My question
is can 4 wire extension cable be used to extend 3 wire cables or 2 wire cables and a 3 wire extension extend a 2 wire?
In addition could a 4 wire extension cable extend 2 2 wires assuming at no point the wires from separate motors interact?
Pretty much can I use extension cables however I want assuming it doesn’t impact the ability of a motor?
Perfect thanks
Similarly the rules state that you may not Y cable off of a Y cable on a motor port. Is usinga Y cable off of a Y cable for a sensor port allowed? Example being 3 soloniod cables going into one port.
