f. Non shattering plastic from the following list; polycarbonate, acetel monopolymer (Delrin),
acetal copolymer (Acetron GP), POM (acetal), ABS, PEEK, PET, HDPE, LDPE, Nylon (all
grades), Polypropylene, FEP; as cut from a single 12" x 24" sheet up to 0.063" thick.
i. Plastic can be mechanically altered by cutting, drilling or bending etc., but it cannot be
chemically treated, melted or cast. Teams may heat the polycarbonate to aid in bending.
I wanted a straight answer so I am asking here.
From my understanding, we are allowed to use any thickness of Polycarbonate, as long as it is cut from a single 12"x24" sheet.
So, it is legal to use lexan thicker than the specified β0.063"β? i.e. 0.83"?
Thank you Karthik
Karthik
December 5, 2012, 10:02am
#2
Thank you Karthik
Please be sure to read the manual thoroughly before posting any questions in this forum. The answer to your question is spelled out exactly in the rule you quoted. To make things clear, Iβve re-quoted the rule and bolded the pertinent text.
VEX Sack Attack Game Manual:
f. Non shattering plastic from the following list; polycarbonate, acetel monopolymer (Delrin), acetal copolymer (Acetron GP), POM (acetal), ABS, PEEK, PET, HDPE, LDPE, Nylon (all grades), Polypropylene, FEP; as cut from a single 12" x 24" sheet up to 0.063" thick.
0.83" lexan is clearly thicker than 0.063" lexan, thus it would be illegal.
https://vexforum.com/showthread.php?t=74681&highlight=lexan#2
In that thread you said:
You are allowed to use different thickness of polycarbonate, however, you are still limited to 12"x24". For example, if you use .03 material, this does not entitle you to use twice as much.
So I am confused. From reading that thread it seems like we are allowed to use any thickness of polycarbonate.
Oh, I was talking about the 0.083" lexan I saw at Lowes. I forgot to add the 0.
Karthik
December 5, 2012, 4:23pm
#4
0.030 is less than 0.063
0.083 (and 0.83) is greater than 0.063
I will quote the rule one final time.
You can use any thickness of lexan, as long as itβs thinner or equal to 0.063"
As said earlier, please read the manual (and past Q&A entries) very carefully before posting questions in this forum.
