If the VEXnet USB Adapter Key on the joystick fails mid-match, can it be replaced with another provided we have a replacement key with us at the field?
The only rule I found regarding Joysticks was
However, I don’t believe “no modification of these transmitters” is referring to changing keys in the middle of the match, correct?
Just to be clear, I was referring to replacing the VEXnet key on the joystick, not on the cortex. Does your previously posted ruling only apply to replacing the cortex’s key, or both the cortex’s key and joystick’s key?
If it is the latter case, is this just a rule I missed? Or is it just “common sense?”
