Is there a different template for the Robot Skills Challenge for RobotC? Or do we just change the time it operates in Operator Control to 60 seconds? In the Programming Appendix there is only one template for RobotC, but muiltiple for EasyC.
You set the Operator Control time to 60-seconds, and the Autonomous Time to 0-seconds. Volunteers will also be there to make sure all robots abide by the correct timing.
RobotC does this differently than EasyC.
John,
If you are using vexnet instead of crystals are you still required to change the timing or is this done automatically by the field control system?
Same question for the programming skills challenge.
