Who
April 24, 2013, 5:31pm
#1
If a robot is in contact with two alliance starting tiles (Both its own color) during autonomous, is repositioning allowed under <SG4>? What about under ?
<SG4>:
<SG4> During the Autonomous Period, Drivers and Coaches may handle their own Robot while the
Robot is in contact with their own Alliance Starting Tile (i.e. the tile the Robot started the match on), and
not touching the Bump, within the following restrictions.
i. Drivers and Coaches may only interact with a Robot if it is touching their own Alliance Starting
Tile and no part of the Robot is touching a gray foam tile, except the interaction allowed in
ii. If any part of a Robot is touching a grey foam tile, the only interaction that will be allowed is to
bring the Robot fully into the legal Alliance Starting Tile, into a legal position as per <SG4i>
iii. After any legal interaction with the robot by Drivers and Coaches, and prior to the robot
attempting to score or interact with Game Objects, the robot must be in a position such that it
is touching the legal Alliance Starting Tile and no part of the Robot is touching a gray foam tile;
a legal position as per <SG4i>. i.e. Before the Robot leaves the Alliance Starting Tile, Drivers
and Coaches may not be touching the robot. If Drivers and Coaches touch the Robot again, it
must be touching a legal Alliance Starting Tile and it must immediately be brought fully back
onto the tile.
Note: Robots that hang over the edge of the Alliance Starting Tile, but do not touch any gray
foam tiles, are considered to be in legal positions for interaction as per <SG4>
iv. Drivers and Coaches may only interact with a Robot if they are on or in the general vicinity of
the Alliance
Drivers and Coaches may interact with their robots as specified in <SG4> of Section 2 – The Game,
with the following additional restrictions:
i. Drivers and Coaches may only interact with a Robot if it is touching an Alliance Starting Tile of the
same color as the one they started on and no part of the Robot is touching a gray foam tile, except
ii. If any part of a Robot is touching a grey foam tile, the only interaction that will be allowed is to bring
iii. After any legal interaction with the robot by Drivers and Coaches, and prior to the robot attempting to
score or interact with Scoring Objects, the robot must be in a position such that it is touching a legal
Alliance Starting Tile and no part of the Robot is touching a gray foam tile; a legal position as per
. i.e. Before the Robot leaves the Alliance Starting Tile, Drivers and Coaches may not be
touching the robot. If Drivers and Coaches touch the Robot again, it must be touching a legal
Alliance Starting Tile and it must immediately be brought fully back onto the tile.
Note: Robots that hang over the edge of the Alliance Starting Tile, but do not touch any gray foam
**This answer was changed on August 9th, 2013. The updated answer is here:
https://vexforum.com/showpost.php?p=336745&postcount=2
