Answered: SG9 clarification
SG9 states "<SG9> Robots may not interfere with an opposing Alliance’s Building of Skyrise Sections in any way. The
following actions are all illegal.
a) Contacting an opponent’s Autoloader and/or contents. (See Figure 22)
b) Contacting an opponent’s Skyrise Base and/or Skyrise. (See Figure 23)
c) Contacting an opponent’s Alliance Starting Tile or the grey foam field tile between the two
Alliance Starting Tiles and located in the corner of the field. (See Figures 24-25)
d) Contacting an opponent’s Robot that is contacting the foam field tiles mentioned in c) and not
contacting any other foam field tiles. (See Figure 26)
e) Contacting any Scoring Objects that are contacting the foam field tiles mentioned in c) and
not contacting any other foam field tiles.
f) Depositing Scoring Objects in/on the opponent’s foam field tiles mentioned in c) or on Robots
or Scoring Objects touching said tiles.
Please note that both direct contact (e.g. Robot making contact) and indirect contact (e.g. Robot
contacting a Scoring Object that makes contact) are considered violations of the above listed clauses.
Does this mean that a robot that is fully within its starting tile and grabbing a cube on the floor that is outside the protected area is still off limits to touch by the other team so long as the robot is not touching the grey tiles? It would seem that is the case, but I want to make sure. Additionally, it would seem as though it would be illegal for an opposing robot to take the cube from the robot that is on its starting time even though the cube is on the ground.
Yes, this is correct.
Thank you!
You’re welcome!
