In sg10, it states stars that are broken into multiple parts should not be scored . In this case, should the stars be removed from the field if refs can do so safely? because the broken stars lying on the ground can cause some robots to get stuck on it and lose mobility for the rest of the match
No, referees will not remove any Scoring Objects, broken or otherwise, from the field.
