Our team is considering having our robot split into two separate robots. The Coretex will be located on one of the robots and the second robot will be wired in with long PWM cables. We were thinking of wrapping it in the Anti-Slip mat to keep everything together and keep it nice and padded. The robots will be driving separately at a distance of approximately 18 inches apart. Would this be considered an entanglement risk? Would it be considered just a Wall Bot? If yes to any of the above, could you suggest any possible way of re-designing the tether to keep all bots safe on the field? Thank you.
Edit/Delete Message
Any type of split robot has the potential to be an entanglement risk, if proper precautions are not taken. From what you’ve described, it is not possible for us to judge the risk of entanglement.
