Answered: Starting Position - Spring Loaded Mechanisms
Is it legal to have either the alliance partner robot or the wall act as a way of holding a starting position of the appropriate size. for instance having the robot backed up against the wall being 18x18x18 but when it drives away it expands out to a bit larger using elastics.
It would probably be impossible to use the wall as a means to “hold” a spring-loaded mechanism in place without violating <R4> which states:
Pay particular attention to the section which is bolded in the above snippet.
yeah i was thinking about that. thanks for a quick response. i had a feeling you would say exactly what you said but i would be mad if i didn’t ask and then it was legal after i thought about a new more complicated way of doing it.
Thanks Again
~DK
