If the robot fits in the measurement area required for size of robot, can the robot overhang the back wall.
Thank you
The Starting Position is defined as the following, with a portion bolded for emphasis:
Starting Positions – The two designated 11” x 20” spots on the field where Robots must start the Match. Starting Positions are bounded by the inner edges of the long black lines, outer edge of the short black line and the top most outer edge of the field perimeter.
Figure 8 also provides a visual representation of the Starting Position. The Starting Position includes the field perimeter wall, so Robots may hang over it, but they may not extend beyond it.
