Answered: stashed definition?
In the rule book it states that a goal extends infinitely, there fore if your opponent were to tip the goal over, or if the goal was improperly attached and it fell over. Then would the objects at the top and bottom of the goal, next to the top or bottom of the goal be scored?
The rule book under the definition of “stashed” it states: “note: the goal extends infinitely perpendicular to the playing field surface.” So if the goal was tipped over, would Bucky balls and big balls on top of the long side of the goal count as stashed?
All definitions in the Manual assume the Goal is in an upright position as per Appendix A. If the Goal were to tip over during a Match, the Match would most likely be replayed as per <G14>, which is quoted below.
If a Robot managed to tip over a properly assembled goal, they would be disqualified as per <S1> for damaging the field.
