Due to some dependencies between these scenarios, it may be helpful to read the whole text to get my meaning, before answering any.
There is a slight difference in wording between A and B:
A: the definition of “scored” (which allows not being “upon a goalpost”),
B: the Scoring section “A tube that is scored upon a goalpost”
Can the section B “upon a goalpost” be disregarded, so that every tube that meets the longer full definition of “scored” counts for 2 points? -
Each tube is either scored, or not scored, so it can’t be counted more than once for the 2 points, right?
Consider one tube scored on the wall goal, (as in picture in rules under definition “Scored”); Now consider a stack of **six **additional tubes adjacent to it on the floor, with the top of the stack touching the scored tube on the wall goal.
**Five **of the tubes on the stack are not touching the foam floor, but are in a touch-chain leading up to the scored wall goal tube, so these five count as ‘scored’, right? -
In #3 (if right, else disregard), all the five scored tubes plus the wall goal tube contribute toward ownership of the goal, right?
Consider that the mobile goals may be moved to be adjacent to other goals. A stack of tubes on two adjacent goals may qualify as being scored on more than one goal. In the case where there is a mix of tube colors, how is goal ownership assigned?
Here is an example:
5A: A goal has scored on it two blue tubes, and one of them touches one of four red tubes scored on another goal. By the touch-rule, all 6 tubes count as scored by relationship to both goals.
Here are some potential rule interpretations I have brainstormed:
A: Each goal is considered in turn; all tubes that could possibly be assigned to that goal contribute to ownership of that goal.
In Example 5A: blue owns both goals. This is “winner takes all”.
B: Each tube is considered in turn, and assigned to contribute to the ownership of only one goal.
In Example 5A: goal ownership is split, blue owns a goal, red owns the other
C: other?
Thanks for consideration.
