Answered: VEX net trouble
Hi we are having problems with our VEX net upgrade…
When we turn on our robot and controller. The vexnet on the robot will have the vexnet light up green. While the other 2 vexnet lights don’t light up.
On our controller the only light that lights up is the robot light and it is green.
So basically the only lights on are the robot light on the controller and the vexnet light on the microcontroller are on.
We used the usb cord and connected it to the robot and controller. That led to the same result of the robot light on the controller and the vexnet light on the brain.
Then we tried configuring it by pressing the button. So we pressed the config button while it is off. then turned it on. All 3 lights on the controller and microcontroller when we tried it on either one lit up green.
What should we do now?
Try using the VEXnet Firmware Upgrade Utility Tool located on our Downloads page. Follow the instructions that come inside the zip file.
Thank you for that response but it did not work.
What happens when you use the Tool? What does the tool indicate?
The tool shows contact vex for acess code and new ID. Can you make me one?
Yes, please email me your User Key displayed in the Tool to ricky_torrance@vexrobotics.com
