Answered: Vex Program Execution Problem
Hi All,
I’ve got a VEX that is behaving oddly. Here is the setup:
RobotC 1.70 w/ MasterCode V8e and firmware 0780
Just a single touch sensor attached for testing.
The program is a simple run until button pressed, then stop.
#pragma config(Sensor, in1,    touch,               sensorTouch, int1)
task main() {
  while(SensorValue(touch) == 0) { // do nothing }
Mastercode, firmware, and program all download without any errors.
Intermittantly, when the program runs I am getting an error message in the Program Debug window:
Failure Reading brick status more
I saw an error message once about not being able to read from the flash memory, but I can’t seem to get that message to show up in the Program Debug window again, I suspect it may be below the bottom of the window if it’s there every time.
The same computer, same code, different Vex and I do NOT observe these problems.
Is there a way to ‘hard’ reset the Vex or is there a test suite to test the internals of the Vex.
Thanks
D. Sean Kelly
Texas Institute Of Education Robotics, Technical Consultant
[email protected]
If all things are the same except for changing out the VEX Microcontroller and one has issues and the other one does not, you will need to contact us for a RMA (Return Merchandise Authorization) number to be able to return the unit to us for repair.
