Does anybody know where I could buy some of the same type connectors vex is using? I would like to add some accessories to the bot on the available 5v outputs.
Here are the connectors I use. They are not keyed, so it is possible to plug the connector in backwards if you are not careful, but they work great. You have to buy the connector shell and the pins separately. It is also a good idea to buy the crimping tool to crimp the pins to the wires.
From Jameco.com
http://www.jameco.com/Jameco/Products/ProdImag/157382.jpgThree-pin Housing (note: 10-position shown)Jameco p/n 157382CJ
http://www.jameco.com/Jameco/Products/ProdImag/145358.jpgMale Pins - Jameco p/n 145358
http://www.jameco.com/Jameco/Products/ProdImag/100765.jpgFemale pins - Jameco p/n 100765CJ
http://www.jameco.com/Jameco/Products/ProdImag/159265.jpgCrimp Tool - Jameco p/n 159265CJ
http://www.jameco.com/Jameco/Products/ProdImag/103229.jpgI also bought some 20-position 2-row connectors that can be cut down and used to make 2x3 connectors - Jameco p/n 103229CJ
and some 36-pin housings that can be cut to any length - Jameco p/n 103157CJ
Thanks! That’s exactly what I was looking for.
