Answered: VEXNet - How do you turn it off?
Is there a correct procudure to turn VEXNet off? Sometimes the VEXnet Microcontroller Upgrade Module turns off with the VEXnet Transmitter Upgrade Module switch, sometimes with the Microcontroller power switch, and sometimes the only way to turn it off is to unplug the battery?
So how are you supposed to turn off the VEXnet Microcontroller Upgrade Module?
You should always turn OFF the Transmitter first. Then turn OFF the Microcontroller, it will shut down in about 3 seconds. The Microcontroller will never should down if it has a link with the Transmitter, unless the Battery is removed.
