Answered: VEXNet Support
Hi, my Tx & Rx VEXNet upgrades will not link. When I go through the linking procedure, the Tx will slowly flash green on the robot LED and once every 10 seconds all LEDs will flash red. The Rx does almost the same thing, except that it will usually be flashing yellow on the VEXNet LED (Instead of green robot LED) before it flashes red. What can I do?
Thanks,
Legotycoon
**For a possible fix - please see my post here:
https://vexforum.com/showpost.php?p=101971
If that does not resolve the issue - please contact us directly at 903-453-0802.
The R/X unit is behaving normally. The T/X unit needs to be reset by following the instructions in the post I have referenced above. The LEDs on both are essentially cycling, going from a “looking for link” to resetting and then re-seeking.**
