I have a (large) list of parts that I would like the weights of. The more precise the better, but I’ll take anything I can get. The reason for this is so that I can allow my CAD library to be as accurate as possible, so I can get a good weight estimate on robots/mechanisms I build. Autodesk Inventor allows me to get an estimated weight based on the volume of the part and the material, but I’d like to have more accurate weights. I was able to find the weights for many of the parts on their Product Pages, but a lot of them (mostly the steel/aluminum parts) did not have those listed. So here’s the list:
Motor Controller 29
2.6" diameter Turntable Bearing
4.25" diameter Turntable Bearing
64-Tooth Spur Gear
84-Tooth Spur Gear
Worm Gear
Worm Wheel
Differential Frame
24-Tooth Bevel Gear
High Strength 12-Tooth Gear
High Strength 36-Tooth Gear
High Strength 60-Tooth Gear
High Strength Square Gear Insert
Free Spinning Gear Insert
10-Tooth Sprocket
15-Tooth Sprocket
24-Tooth Sprocket
40-Tooth Sprocket
48-Tooth Sprocket
High Strength 6-Tooth Sprocket
High Strength 12-Tooth Sprocket
High Strength 18-Tooth Sprocket
High Strength 24-Tooth Sprocket
High Strength 30-Tooth Sprocket
Tread Link
Tank Tread Traction Link
Conveyor-belt Base Link
Short Conveyor-belt Insert
Medium Conveyor-belt Insert
Tall Conveyor-belt Insert
Bevel Gearbox Bracket
Worm Gearbox Bracket
Rack Gearbox Bracket
Inner Slide Member
Outer Slide Member
Steel Swerve Bracket
Intake Roller
2.75" Diameter Wheel
4" Diameter Wheel
4" Diameter Wheel with High Traction Tire (Or just High Traction Tire?)
5" Diameter Wheel
2.75" Double-Roller Omni-Directional Wheel
Pillow Block Bearing
Lock Bar
Shaft Collar (with set screw installed)
Steel Washer
Teflon Washer
Spacer, 4.6mm
Spacer, 8mm
Spacer, 0.125"
Spacer, 0.250"
Spacer, 0.375"
Spacer, 0.500"
Cylinder, Air Push, Spring Return
Solenoid, On-Off
Cylinder, Bi-directional
On-Off Switch
Solenoid, Fwd, Reverse
Fitting for Cylinders
Fitting for Reservoir
Fitting for Valves
Flow Meter
Plug for Reservoir
‘‘T’’ Fitting
Aluminum Chassis 25x25x2
Aluminum C-Channel 1x2x1x25
Aluminum C-Channel 1x5x1x25
Aluminum Plate 5x25
Aluminum Bar 1x25
1/4" Pitch Angle, 1x1x10 holes
1/4" Pitch Angle, 1x1x30 holes
1/4" Pitch Bar, 10 holes
1/4" Pitch Bar, 30 holes
1/4" Pitch C-Channel, 1x3x1x10 holes
1/4" Pitch C-Channel, 1x3x1x30 holes
1/4" Pitch Plate, 10x10 holes
1/4" Pitch Plate, 10x30 holes
Aluminum C-Channel 1x2x1x35
Aluminum C-Channel 1x5x1x35
Aluminum Angles 2x2x35
Plate 15x5
Plate 25x5
Angle 2x2x35
Angle 2x2x25
Angle 3x3x35
Chassis Rail 3x2x35
Chassis Rail 2x1x35
Chassis Rail 2x1x25
C-Channel 1x2x1x35
C-Channel 1x5x1x25
C-Channel 1x5x1x35
Short Slotted Angle
Slotted Angle
Slotted Angle, Inverse
Bar 1x25
Drive Shaft Bar Lock
45 Degree Gusset
Pivot Gusset
Angle Gusset
Plus Gusset
Hinge
Screw 6-32 x 0.500" Silver
Screw 6-32 x 0.250" Silver
Screw 6-32 x 0.500" Locking (Assuming the same as Screw 6-32 x 0.500" Silver
Screw 8-32 x 0.250"
Screw 8-32 x 0.375"
Screw 8-32 x 0.500"
Screw 8-32 x 0.625"
Screw 8-32 x 0.750"
Screw 8-32 x 0.875"
Screw 8-32 x 1.000"
Screw 8-32 x 1.250"
Screw 8-32 x 1.500"
Screw 8-32 x 1.750"
Screw 8-32 x 2.000"
Screw 8-32 x 0.500" Locking
Screw 8-32 x 0.250" Locking (Assuming the same as Screw 8-32 x 1.250" and
Screw 8-32 x 1.500" )
Nut 8-32 Nylock
Nut 8-32 Hex
Standoff 0.25"
Standoff 0.50"
Standoff 0.75"
Standoff 1.00"
Standoff 1.50"
Standoff 2.00"
Standoff 2.50"
Standoff 3.00"
Standoff 4.00"
Standoff 5.00"
Standoff 6.00"
Coupler 8-32 x 1.000"
Coupler 8-32 x 0.500"
Flexible Rubber Link
Battery Strap
Yaw Rate Gyroscope Sensor V1.0
Ultrasonic Range Finder
Analog Accelerometer V1.0
Jumper
Backup Battery Holder
Backup Battery Cable
VEXnet USB Adapter Key
If VEX does not have the weights of these parts for some reason and that is why they are not on their product pages, then that is fine – just let me know and I’ll just ask the VEX Community and/or make a trip to the post office one of these days. Otherwise it would be great if these weights could be put on the product pages.
Thanks so much!
~Jordan
JVN
June 2, 2011, 6:00am
#2
Hi Jordan,
I’ll get my new crop of summer interns to start weighing. We’ll have all that posted… whenever we finish weighing everything.
-John
PS - You are now the least popular person in the VEX intern lab.
LegoMindstormsmaniac:
Motor Controller 29
64-Tooth Spur Gear
84-Tooth Spur Gear
Worm Gear
Worm Wheel
Differential Frame
24-Tooth Bevel Gear
10-Tooth Sprocket
15-Tooth Sprocket
24-Tooth Sprocket
40-Tooth Sprocket
48-Tooth Sprocket
Tread Link
Inner Slide Member
Outer Slide Member
Intake Roller
4" Diameter Wheel
5" Diameter Wheel
Lock Bar
Steel Washer
Teflon Washer
Spacer, 4.6mm
Spacer, 8mm
Spacer, 0.125"
Spacer, 0.250"
Spacer, 0.375"
Spacer, 0.500"
Solenoid, On-Off
On-Off Switch
Fitting for Valves
Flow Meter
Plug for Reservoir
‘‘T’’ Fitting
Aluminum Plate 5x25
Aluminum Bar 1x25
Plate 15x5
Plate 25x5
Angle 2x2x35
Angle 2x2x25
Angle 3x3x35
Chassis Rail 3x2x35
Chassis Rail 2x1x35
Chassis Rail 2x1x25
C-Channel 1x2x1x35
C-Channel 1x5x1x25
C-Channel 1x5x1x35
Short Slotted Angle
Slotted Angle
Bar 1x25
45 Degree Gusset
Pivot Gusset
Angle Gusset
Plus Gusset
Hinge
Screw 8-32 x 0.250"
Screw 8-32 x 0.375"
Screw 8-32 x 0.500"
Screw 8-32 x 0.625"
Screw 8-32 x 0.750"
Screw 8-32 x 0.875"
Screw 8-32 x 1.000"
Screw 8-32 x 1.250"
Screw 8-32 x 1.500"
Screw 8-32 x 1.750"
Screw 8-32 x 2.000"
Nut 8-32 Nylock
Nut 8-32 Hex
Standoff 0.25"
Standoff 0.50"
Standoff 0.75"
Standoff 1.00"
Standoff 1.50"
Standoff 2.00"
Standoff 2.50"
Standoff 3.00"
Standoff 4.00"
Standoff 5.00"
Standoff 6.00"
Battery Strap
Jumper
Thanks so much!
~Jordan
Hi Jordan,
-John
Thanks so much, JVN!
~Jordan
P.S. I had a feeling that I’d make someone unhappy.
Mr. John:
I hate to be a bother, but I was wondering how far along this has gotten. I have not yet taken a scale to weigh all these, but I think I’ll start using Mr. Blake’s weights he gave awhile back for some of the structural pieces.
Unless this has gotten somewhere and the weights are simply not put up yet? Anyway, just looking for an answer. I’m glad that the new parts mostly include their weights, but I feel that the old parts should be updated to be as informative.
Thanks!
~Jordan
