Answered: WHat is the code for the Ycable?
Hi, i am wondering what the code is for a “y” cable, so that i can run two motors simultaneously? thanks
If I am understanding you question correctly, your wonder what coding you would need to program for a “Y” cable.
If that is correct, then you would not need any special coding for the “Y” cable, you would code normally for a single motor, and then just connect the 2 motors to a Y cable and then connect the Y cable to the corresponding motor port. This will give you simultaneous motor control.
Serial Y-Cable
P/N: 276-1579
