Answerws: Micro controller Problem.....
I have a problem. I was programming my Vex Microcontroller ( I bought my Vex Starter kit in march) using easy c v.2 and the programming light stays on and it will not run motors but will recieve imput from sensors when in online mode. I have tried to do this:You can download code using our IFI Loader that is available on our Downloads web page http://www.vexlabs.com/vex-robotics-downloads.shtml. Go to our Downloads web page and get the Vex Master Code and Vex Default Firmware zip file and our IFI Loader if you do not have them. Inside this zip file you will find a VEX_MASTER_Vx.BIN file. Using the instructions called UpdatingMasterFirmware.pdf download the latest Master bin file to the Vex Controller using the IFI Loader. After this is complete, you will need to download the Default Firmware (hex file) to the Vex Controller. That was found in Another answer but I cannot see the files other than HEX files when trying to browse for them to download via the Intelitec loader… any Help would be appreciated.
Dominic Rankin.
For the IFI Loader - Use the instructions called UpdatingMasterFirmware.pdf. Not sure if they apply to easyC. If you need help with easyC, please post your question in the easyC section.
Thank You very much, I got it fixed.:smiley:
