Hi - we just discovered our the competition port on our remote is broken and hoping someone had some good work-arounds - legal or not!
Are you talking about just the clip that “clicks” the cable in? If so, I’ve seen a lot of teams wrap a rubber band around their controller and then attach that to the cable each match. This helps to “hold” the cable into the port so it doesn’t fall out.
Yes, the ‘non-clipping cable’! SO I guess they simply rant the cabue under the VEXlastic!?! Brilliant! Thanks for quick fix Ethan!
