Any errors with my program
Stugg stugg2
Yes.
Whats the problem with the program
Add a " } " to close the else bracket.
this is two photos that back on each others
Stugg paod
Given that you’re posting here, I’m assuming that it doesn’t do what you want it to do, so if you tell us what you were trying to achieve and what it’s doing instead, we might be able to help.
this is how it looks in the program
add bracket here and it should run.Capture_LI
our arm doesnt lift
E45DCFE1-B0A2-4BDF-AA9A-466666BACEE4 D155969D-2759-4D6F-95D6-5289BD659A8A
If you are operating the arm motors via controller 2 joystick, you should not have them stopped in your button code (delete references to arm motors in else .stop section).
Left arm and right arm are both set to rev on bottom and top; is this correct? Looking at your setup, maybe one side needs to be fwd and one side rev? I would pull the motors off the axles and do some tests for direction and check code without arms attached…
I think you have build problems also (I know those are being addressed in another thread - you probably should have just made 1 thread). For one thing, setting the motors at different ratios top and bottom all trying to run the same arms will cause issues (and it looks like maybe top and bottom sections are working against each other?). For another, v5 has plenty of power to run this (with claw) on 2 motors so you shouldn’t need 4…
Where working on taking off the top motors
First up is to make sure of your diagnosis. Have you connected motors without loads to those ports and verified that motors on those ports are or aren’t being driven?
Hey, just want to thank you for all our help we put rubber bands on and took of the motors and it works beutifully thanks for all you help! :grinning:
