Tank: One joystick controls one side of the drivetrain while one joystick controls the other side. (Your requested setup)
Arcade: One joystick controls forward motion while one joystcik controls left right motion. (Much like driving an RC car, and IMO, much more intuitive)
its all what you prefer really, i personnaly like arcade a lot more just beacuse im used to it. murdomeek is right tho because tank drive can make more precise movements, you just have to be used to it.
Tank mode uses both thumbs, so it limits the controls available for arms and other mechanisms. If you have a second driver for mechanisms, tank is not so bad.
I don’t know, maybe it does. I just call it arcade for holonomic drive.
Yes you can, but I just find it easier to let the program take care of all the holonomic stuff for me (I’m the programmer, so I may be biased). If you put it on tank drive, I find that small imperfections in the position of the two joysticks (if you’re not going full speed of course) will throw the robot out of whack more than a non-holonomic drive.
I find that a tank drive is actually pretty easy to drive even with a manipulator to deal with as well. It’s when you start trying to use a holonomic with a manipulator that you run into to trouble. Either way, we try to separate the two functions so they can each be driven more precisely.
Programming also reduces the load that the driver has to handle. Take 1103 for example. He did tank drive and he still was able to drive that thing like a boss because he had a ridiculous program.
Like most people have already said, tank gives more precise control over turns. Moving one joystick more than the other results in a turn with a larger arc as opposed to a turn that keeps the robot in the same place.
Personally, I find that this precision is generally unnecessary. Arcade drive with a normal non-holonomic chassis gives the driver less to worry about in terms of controls and more time to survey the match situation.
In a standard 4WD without strafing capabilities, tank control can be really useful for precise movements side to side. By tweaking the controls somehow (I’ve never driven our robot for competition), the bot can move sideways very small increments for fine adjustment fairly quickly.
It is best if you have a separate coach to monitor the game and direct strategy rather than having the drivers do it. Drivers are required to focus on details, such as manipulating the robot and positioning to score, so it is extremely hard to do that effectively and still watch overall field position, game score and other big picture things. Of course, if you don’t have a coach, then simplifying the driving controls or practicing for ridiculous lengths of time are good ideas.
Actually, Arcade drive normally refers to using a single joystick to control both forward/reverse and turning. The default program for the Cortex (I don’t have a 0.5 Pic, but guess it would be the same) has the option of tank or arcade mode. Try putting a jumper in digital input 12 to switch from tank mode to arcade mode.
The FRC team I mentor as well as both VEX teams I coach prefer the maneuverability of tank drive over arcade. They have not done holonomic drives because of the loss of pushing force.
I would suggest you use whichever method is best for your driver. We have programmed both tank and arcade options for our driver tryout so each driver can choose what they are the most comfortable with.
