Attempting to code a distance sensor to detect speed like a Radar Gun.
I recently tried to find an object’s speed with a distance sensor, while I could use a timer and use the distance formula, I decided to try to create a code that would automatically find the constant speed of an object.
Code:
int Brain_precision = 0;
float Variable1, Variable2;
// "when started" hat block
int whenStarted1() {
  Brain.Timer.reset();
  while (true) {
    if (Distance12.foundObject()) {
      Variable1 = Distance12.distance(mm);
      wait(0.25, seconds);
      Variable2 = Distance12.distance(mm);
      Brain.Screen.print(printToBrain_numberFormat(), static_cast<float>((Variable1 - Variable2) / (Brain.Timer.value())));
    else {
  wait(20, msec);
  return 0;
int main() {
  vexcodeInit();
  whenStarted1();
Are there anyways I can improve this code.
