Auto Stacking
Our auto stacking code is not working. Our Scissor lift just goes up to the max height then stops, then it runs the chainbar code.
#pragma config(Sensor, in1, POT, sensorPotentiometer)
#pragma config(Sensor, dgtl7, rightEncoder, sensorQuadEncoder)
#pragma config(Sensor, dgtl9, leftEncoder, sensorQuadEncoder)
#pragma config(Sensor, dgtl11, Sonar1, sensorSONAR_inch)
#pragma config(Motor, port1, rightMotorB, tmotorVex393HighSpeed_HBridge, openLoop, reversed, driveRight)
#pragma config(Motor, port2, rightMotorF, tmotorVex393HighSpeed_MC29, openLoop, reversed, driveRight)
#pragma config(Motor, port3, ConeLift, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port4, ScissorRight, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port5, ScissorLeft, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port6, ConeLift2, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, ArmMotors, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, ConeGrabber, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port9, leftMotorF, tmotorVex393HighSpeed_MC29, openLoop, driveLeft)
#pragma config(Motor, port10, leftMotorB, tmotorVex393HighSpeed_HBridge, openLoop, driveLeft)
void ChainBar( int ArmPos)
wait1Msec(1000);
	while(SensorValue[POT] > 700)
		  motor[ConeLift] = -127;
                      motor[ConeLift2] = -127;
void ScissorUp( int Speed1, int Speed2)
if(abs(SensorValue[leftEncoder]) > abs(SensorValue[rightEncoder]))
motor[ScissorRight] = Speed2;
motor[ScissorLeft] = Speed1;
if(abs(SensorValue[leftEncoder]) < abs(SensorValue[rightEncoder]))
motor[ScissorRight] = Speed1;
motor[ScissorLeft] = Speed2;
if(abs(SensorValue[leftEncoder]) == abs(SensorValue[rightEncoder]))
/* ScissorLift Adjustment /
void ScissorLift( int Dist )
while(SensorValue[Sonar1] < Dist && SensorValue[rightEncoder] < 90 && SensorValue[Sonar1] != -1)
ScissorUp( 90, 90 );
/* ScissorLift Down /
void ScissorDown (int Speed1, int Speed2)
motor[ScissorRight] = -Speed2;
motor[ScissorLeft] = -Speed1;
motor[ScissorRight] = -Speed1;
motor[ScissorLeft] = -Speed2;
task usercontrol()
resetSensor(rightEncoder);
resetSensor(leftEncoder);
      while (true)
      		if(vexRT[Btn5UXmtr2] == 1)
                        ScissorLift ( 18 );
                       ChainBar( 300 );
Do you ever stop the motors?
In the While Statement if the Sonar senses > 18 it should stop everything. The Scissorlift( 18 ); works on its own but when we added the ChainBar it stopped working.
I think your question was answered in a thread that I posted here:
Hopefully that helps.
I tried to post a link, that didn’t work.
https://vexforum.com/t/im-missing-something-simple/46143/1
