Autodesk help
I am fairly new to Autodesk and I don’t have a whole lot time to mess with it for hours on end. I am wondering how to place multiple pieces in the same file. Every time I open a different part it just brings up a separate file. by the way I use the Imperial file that contains all the parts, in case that helps. :slight_smile:
Create an English Standard Assembly (.iam) and then you can click the Place button on the top left corner of the Assemble tab
Thank you!!!
