Autodesk Inventor Pro - Rotating a Vex Hinge
I cannot figure out how to rotate a vex hinge around the middle pin. ANy help would be great! Thanks!
Did you make the assembly flexible?
No… How do I do that?
If you are using an assembly such as the hinge, inside of an assembly such as your robot assembly, you will need to turn on flexibility for the hinge in order to allow it to function inside of your robot assembly. To do this, simply right-click on the hinge, and click “Flexible.”
~Jordan
Thank you Jordan!
You’re welcome!
Are you copying Karthik now?
:stuck_out_tongue:
It’s Karthik Junior!
