Autodesk Inventor Wheels
I just can’t seem to figure out a way to place the wheels down. Every time I try to, it comes up with a resolve link popup and I’m not too sure on what to do.
That means the wheels component files have been moved or deleted. You should re-download the wheel and all it’s components
Just tried that and didn’t work.
Im using these files 2018 BNS/VRC/SID Library - Google Drive
Do you have the part that it is trying to resolve? If you have the part in the download you should be able to tell autodesk where it is.
The 4" omni wheel is made up of multiple parts so i’m not too sure which one to select
Hi @Yuma123
Follow the folder path for your computer, mine looks like this:
C:\Users\\Downloads\2018 BNS-VRC-SID Library\Motion\Wheels _ Rollers\Reference Parts\4_ Omni-Directional Wheel
In the wheels_rollers folder you should have ReferenceParts then follow it down to the part list and inside of that folder is all the reference parts.
If you do not have that, might need to re-download. If you load the parts in, then go back and reference the parts individually is sometimes easier then using the wizard screens they have.
Ah i figured it out. Thanks
